I've been looking at the documentation for both the SSC P4 and the Cree XR-E, in particular I was looking at radiation patterns. My interpretation of the graphs is that the SSC puts less light forward and more out to the side (out to 90 degrees) than the Cree (60 degress).
To capture lots of light a thrower needs a reflector that is deep compared to its length to reflect as much of the light radiated by the emitter forwards and minimise spill. The SSC puts out more light sideways instead of forward so in theory it should make a brighter hotspot than the Cree for a given reflector assuming it puts out the same amount of light as the XR-E.
It seems generally accepted on here that a Q5 (and therefore an R2) bin XR-E will produce more light than a U bin SSC P4. So, given that the SSC P4 has an advantage in radiation pattern for a thrower and the Cree XR-E puts out more light, which one will be best for throw with a reflector i.e. (not with an aspheric)?
