You can never get a real technical "answer" to Cree vs. Seoul, it will always be based on the posters impression .
f.e.: not taking into account the positive slug on the P4 (ridiculus) and the parallel driven P7 (not going into detail here) ...
... EVERY of my attempts to build lights with Seouls led to bad ones.
If lucky the output is only very much on the blue side, getting even more blue when raising the current (to be still within datasheet value).
Even when the ratings (which are a joke, do not look at the highest possible lumen from that bin, look at the average or the guaranteed lowest --> here they are always way below the matching cree, which also has the whiter light not changing at more power) are much higher, the (older!) Crees won easily, just by comparing with the eyes ... which means there is quite a difference, as our eyes are not this good.
Compared to that, all my Crees - even the "blue" tinted ones - give a nice white beam,
no rings because I use good reflectors
My best mod so far, a SF 6P modded in April 2006 with a Cree XR-E P4 and 18650 still is brighter than any newer light I have gotten till now. The tint is white (I was able to choose it, which I am not with Seoul).
With all my trustfires, Jetbeam, L-Mini, Xtar, ..., I usually grab the modded 6P
imho most of the good performance comes from the sandwich shoppe 19 mm reflector (which I would have no corresponding one when using a Seoul)
... but do I know if I maybe have made mistakes when using Seouls?
Probably their poor performance is just my fault?
:thinking:
... You see: simply impression
(but I am sure You will get a whole lot more votes for "inconsistent performance" for Seouls)
