I guess I have a hole in my knowledge (many, really) figuring out current limiting resistors. I've got an SST-50 mounted on a heat sink, and tested current draw from a 26650 with a resting voltage of 3.9 v. Current draw with emitter straight to the battery was ~ 4a. With a .47ohm 5watt resistor in series with the emitter, total current draw was only ~1.4a.
Did I mis-measure, or if not, can you explain why this is so?
My plan is to use this SST-50 in a Mag3D direct driven from alkalines, and am trying to determine if I really have to use a series resistor, and if so what value would work best. I'm using the 26650 just because it was much easier... Might there be enough voltage sag, even with fresh alkalines, so that I'd be safe without a series resistor?
If it went from ~4a. to ~1.4a., with some loss (how much)? to the resistor, I'm assuming I'm losing a lot of output.
Here is another question that will show my basic lack of LED operation knowledge - if I stay below the 5a. that the SST-50 is rated for, even though it might be that from 3 fresh D alkalines at 4.5v resting, am I safe?
I will be using a dFlex, so I could use a slightly lower PWM level than max until the battery voltage has dropped a little to make it safe on max, right?
Thanks for any help,
John F
John F
