SST90 multi-driver solution
SmurfTacular
Orange County, CA
Ive been almost exclusively making P7 Maglite mods in the past. And I've decided to move on and start to use higher powered LED's such as the SST-90. I'm more than aware that theres only one driver designed for the SST90 (Der Witchel), but its only a 1 mode. And that you can make your own driver using multiple DX drivers to achieve the ~9amps for full power. I know I cant use four of these, because four of them obviously wont fit inside the vacant room inside a D cell Maglite. So I ordered four of Downloads 2.8amp drivers. My question is, what wiring configuration do I need to wire them to output ~9 amps? Also, I'm using six D NiMh cells, and each DL driver can only take in ~6volts.
This is how I plan to wire up the drivers, but I want to be sure im doing it right, can I get a confirmation please, and maybe some tips? Thanks.
