How do I create a circuit to step up the voltage to run an led?
Please give me some kind of a basic non filtered diagram that shows how to change DC to something that can be processed by a transformer.
I have taken two electronics cources and know that I will obviously need some kind of transformer or autotransformer. The problem is that a transformer will not work with direct current. I probably will need some kind of a transistor/capacitor circuit that chops or inverts the direct current so it can be processed by a transformer. Furthermore, the output of the transformer will probably be some form of a crude AC current that will be pulsating negative and positive; so, I will most likely need a capacitor, inductor, and zener diode to regulate the voltage.
I hope someone can give me a circuit diagram.
Thank you.
BTW, I want to run an led that is designed to run between 3.6 to 4 volts at 4.5 to 5 from a 3v power source that I plan to step up.
I do not mean to be too much trouble, but once I figure out how to build it, how am I going to make it small enought to fit in my flashlight?
Thanks
Thank you.
Thanks
