Stinger bulb in a pr base?
turbodog
central time
I would like to mount a stinger bulb in a regular pr base. Furthermore, I would love to find/make a pr base with a stinger socket in it so the base could be reused between bulbs.
Anyone seen one, got one, want to sell one, would make one for $, could tell me how to make one, knows where I can get parts?
Yes, I have done that and works great with 3C or 3D NiMH M*glight. Much brighter than M*g stock bulb. I also used same type of bulb with single Li-ion cell.
http://www.carleylamps.com/sockets.htm
Carely has PR base socket but they recommend not to use with bulbs more than 1 Amp. Stinger bulb pulls about 1.8 Amps. Here is how to do:
You can also use Carely 1122 (3.5 v 2.3 Amps.) potted on PR base which is even brighter than Stinger. Let me know if you need more help.
Good luck.
See the Tigerlight upgrade thread for some info on ceramic potting compound that you can pot bulbs in. WA and Carley will also pot bulbs for you.
I'm a little confused on why you want to do this. What host are you going to put the PR-bulb in? If you want a mid-sized light (sub-c's) with that type of bulb, why not use a Stinger? If you want a smaller light, use a Strion. If you want a bigger one, use a Magcharger.
Note that a bulb this powerful may be too hot for a typical plastic reflector that you get in a random PR light.
five...
In the picture, were you able to buy a pr base with the socket for a stinger already installed? If so, what's the part # so I can just order it direct. If this device has to be built, what parts do I need?
Paul...
This should be a really easy/clean/neat way to add some pretty good zip to a 3 cell mag/etc. Using a stinger bulb means I can do this w/o using an overdriven bulb, or a hard to find bulb, or an expensive bulb. It will also give some really good runtime.
For the record, I already have a stinger (actually had 3 of them before I sold 2) and a magcharger (with add-on bulbs/batteries/etc).
Also, on the side, I am working on a regulated drop-in mod for a 2 cell mag/etc that will work really nicely with this bulb setup.
Turbodog, I think if you run the Stinger bulb on 3 alkaline cells, you'll flash it. You can run it on three rechargeable cells, but I still don't understand why you'd want to. The same with the 2 cell drop-in mod; why mess with a mod when I can just buy a Stinger or Strion? The 2 cell mod will need a boost converter, losing some efficiency; you'll still have to use rechargeable cells to get such high current, but you'll lose the convenience of the charging terminals on the outside of the light; etc. I just don't see anything that great about the 2D Mag, that would make me want to deal with specially potted, $5+ bulbs.
Note that you can get the Reflectalite GH88 which runs on two cells and should be almost as bright as a Stinger.
Maybe I'm looking at a AA based drop in into a 2d host.
Also... the stinger thing can still work fine in a 3 cell nimh light. Most of this comes back to runtime.
runtime:
stinger - 1 hour
magcharger - 2 hours
stinger bulb in 3d nimh - 5 hours
I'm looking for the pr base so I won't have to pot the bulbs. Having to pot bulbs is the LAST thing I am wanting to do.
Stinger bulb in 3d nimh = a light as big as a magcharger, if you're using a 3d mag. Why not just put the three d's in a magcharger? Then you get charging contacts, bi-pin socket, and metal reflector. You might have to mod the charger a little to charge three d's instead of five 1/2D's, no big deal.
Carley has a bi-pin to PR socket as someone mentioned above, not recommended for such high current, but you may as well give it a try.
Hmm, six AA's in a 2D body running a PWM regulator, that's kind of an interesting idea. Runtime might be in the 2.5 hour range. On the other hand you could put a 3000 mah NiMH pack into your Stinger and get maybe 1.8 hours in a much smaller light.
Have you got a source of 4aa-to-D holders? /ubbthreads/images/graemlins/thumbsup.gif
Note that there's already a perfectly good 8AA light with a Stinger-like bulb: the Princeton Tec Surge. It's unregulated, but much smaller than a 2D Mag.
I'm not telling.
/ubbthreads/images/graemlins/icon15.gif /ubbthreads/images/graemlins/evilgrin07.gif
Turbo,
As I mentioned earlier, # 912 PR base socket is recommended to use with max. 1 Amp. and I never used it. I think it will work for momentary use and not continuous use.
I used PR base bulb, broke off the glass and solder bulb pins to PR base terminals. It takes some work and I did it for my experiment and got good result. But again 1122 (8 watt) is brighter than Stinger (6 watt)
Using 3 alkaline will not flash Stinger bulb but 4 Nimh will.
I got 4 hours of run time per charge on 3D sinse my batteries are old but 5 hours will be reasonable with healthy 9000mAh
Here is another mod using shortened 2D, Stinger bulb and 2 Li-ion in parallel. Smaller and lighter than 2D with 1.5 hours run time and far shooting 2" reflector. 2 Pila also can be used. With some extra machine work possible to place 3 4/3A Nimh (3800 mAh). No need to remove batteries to recharge if you have proper charger.
Short_Mag_004.jpg~original
Short_Mag_002.jpg~original
