Stinger Rechargable replacement
batmanacw
Andover, Ohio
I have a stinger that has been extremely reliable and rugged for the last 10+ years. The battery finally gave out a few months ago and the original bulb is still going strong.
I would love find a good quality replacement for the reflector with an LED. Any options for me?
Wouldn't have any clue. Try searching for that upgrade around here and you might get lucky and find some beamshots. :D
The Terralux conversion is (IMO) horrible: the optic creates a weak, diffuse beam with a weak center spot with all sorts of artifacts, and it has a nasty purple tint. The overall beam strength and quality isn't acceptable.
I'm on the second one, as the first one was so purple (i.e. Barney The Dinosaur purple), I had the vendor swap it out, but the replacement was almost as bad.
WOW :sick2:. Sounds kinda like the LED Lenser I have. Well, the TerraLux was all I could find that "looked" to be worth anything. Bummer :thumbsdow
One of the guys at work just bought that conversion for his Stinger. The beam is anything but clean and artifact-free, but it's pretty bright and a good white tint. When the light is actually being used (not white-wall hunting), the beam is very usable. He is VERY happy with it and glad he spent the money on the conversion.
I've had one of those drop-ins for a few months and I like it. sure, its not a perfect beam, but it beats the heck out of my original bulb!
Stinger Rechargable Replacement
I am trying to recall, is this the only replacement for the Stinger or does/did somebody else also make one similar to this?
Re: Stinger Rechargable Replacement
With the light focused as wide as possible to get rid of the hole in the middle, the beam is really not all that terrible. I will not buy a replacement unless its a drastic improvement. It gives me a pretty solid center spot so I guess it will stay the way it is.
It really has been a reliable light. No complaints other than the artifacts in the beam.
