Finally got around to completing my cree based under cabinet setup for my kitchen.
I am using a VARILED driver, with 16 crees in two channels of 8 in series, running at max current of 350mA per channel.
The variled has a dimming function which is useful since 16 crees at 350mA can be quite bright for night adapted vision!
However today I noticed soething very bizzare. When dimming the system down, at some point near the low end, two or three LEDs in every channel are actually completely OFF. ie as if they were disconected from the circuit. However since other LED in the circuits are in series with the off ones and functioning, it means there is juice in the wires and all is as it should be.
There is quite a bit of difference between where these LEDs switch off, and how far the rest can be dimmed down even more (actually one of them switches off as soon as I move lower than the 350mA maximum setting!)!
Question is, is this behaviour solely due to binning and Vf differences between different LEDs/batches? (the crees are all WDs from DX bought at different times)
Or am I missing something else here?
