Strion bulb for NF-2, TL-2 with 17670 ?
HgRyu
Seoul, Korea
I can't find answer for belows. Anyone tried before ?
Could you put 3.7V strion bulb into NF-2 or TL-2 without modification ?
And Could you use 17670 in NF-2 for strion bulb ?
I think I remember that the Strion and Stinger bulbs would fit in those lights. So, if the cells physically fit, that should work, but you'd have to make sure you're not to overdischarge the cell. A Pila 168 cell would eliminate this risk. Anyway, other than the possibilty to switch back to the original bulb and cr123's I see no advantage in buying a Nf-2 or Tl-2 just to make them what the strion already is. By the way, would two cr123's and a scorpion bulb work in the strion? Of course one would have to make sure not to put it in the charger with cr123's installed. But one could carry a scorpion bulb and two cr123 for emergencies when there's no possibility to recharge the strion.
Chrisse
I put a Pila and a Strion bulb in an NF-2, and it worked fine.
Can't put two 123's in a Strion, as the Strion needs both battery contacts (+ & -) on the same side of the battery (like a Stinger battery).
--dan
