Strion mods?
Aaron
MI
I just got my SL Strion. It has a good runtime, over an hour. It is also pretty bright, slightly brighter than my E2E. Are there any mods out yet that will increase light output? If it were possible to double the light output, it should still run for slightly over 30 minutes. I think it would be totally worth it. /ubbthreads/images/graemlins/smile.gif
Um...not that I know of. A bulb change, maybe...but finding a bulb to fit would be pretty tough.
--dan
It runs slightly brighter using Carley 1122 (3.5 V @ 2.3A) for only 35 minutes. So, even if you find a higher wattage bulb (twice the wattage), run time will be about 10 minutes and don't forget with that kind of load, voltage drop will be severe causing battery damage.
