Well, I admit I don't use rechargables much. But I purchased a new scanner (BC246T if you must know!) and I figured that I'd be running it a fair amount and probably should go for rechargables.
Of course, this was sort of an impulse, so I just stopped at Circuit City on my way home from work (and was in a hurry). Best deal I could find was a Sony charger w/LCD (BCG-34HRMD) that came with (4) 2300 mAh NiMH batteries for $34.
That works fine.
My question?
Well, I'm curious how much I can mix and match chargers? Can I put the GP 1800 mAh NiMH batteries that came with the charger in there? How about the 1800 mAh NiMH PowerEx cells? I also have a Maha charger (Edit: Found it! It is MH-C204F) in a box somewhere that I purchased when 1800 mAh cells were the best you could get (hence the PowerEx cells). Can I put the batteries in there? The higher capacity ones too? If so, which charger would be better?
I told you these were stupid questions...
Thanks!
-john
That works fine.
My question?
Thanks!
-john
