I want to put a sandwich in a couple of lights and am not sure what the correct items to use. Any help would be appreciated.
#1 - for 3 x AA cells, ~4.5V. I would have just ordered a drop in module, but they all indicate a max input voltage of 3.1v. I'm not quite sure I understand this since the Badboy boards are rated 9V input max.
#2 - for 12 x AA, par/ser for 9V.
#3 - I want to use NX05 optics with a 1W LS. I never paid attention what the difference between HD and LD. Do both work with the NX05? One better than the other? I assume the SE has that funky lens built in and does not work with the NX05. Also, how do you rank the qualities of the LSes available from Wayne?
Here are the ones I see:
LXHL-BW01 White Luxeon Batwing (LD) Emitter LED (BIN Q3_)
LXHL-BW01 White Luxeon Batwing Emitter LED (BIN Q2_)
LXHL-BW03 1W Warm White Luxeon LD Emitter
LXHL-MW1C 1W White Star Bin code Q4H (LD)
LXHL-MW1D 1W White Star Bin code R2L (HD)
Thanks,
-john
Thanks,
-john
