lctorana
Question -
could you use a power transistor instead of a MOSFET for Q1?
Question -
The thing with shunt (linear) regulators is that they are not very efficient. Take the example of a 12VDC supply driving a single LED at 0.750A. The power going to the LED is about 2.70W (3.6V x 0.750A). The total power is 9W (12V x 0.75) giving an efficiency of only 30% - 70% of the power is lost as heat (6.3W) which has to be got rid of. The efficiency will go DOWN even further if the supply voltage is increased (it will go UP with lower supply voltages).
A switching buck regulator will typically be 80-90% efficient - lets use 85% as an example. Using the same 12V supply, the buck regulator will draw 265mA instead of 750mA - so for a given battery size, the buck regulator will last 2.83x longer (750/265) than the linear regulator. Also, the amount of power/heat that needs to be got rid off is 0.476W compared to 6.3W - less than 8% of the linear regulator.
A buck regulator is not terribly difficult to put together (a boost, buck/boost or SEPIC is a bit more complex). However, if efficiency is not a concern, then the simplicity of a linear regulator may be a viable solution.
