SureFire A2 - Not All Created Equal ?
Gloucester, New Jersey
So, would these differences be due to the regulation circuit, the LA or both? Everything else is pretty constant. The testing methods, the environmental surroundings, the initial cell voltage, etc.
How about you try swapping the lamps over?
I think perhaps you need to increase the number of output tests you do (say 5 sets on each lamp in each A2) to see whether it's a variation in the batteries or due to the lamp or A2 itself. Did you clean all the contacts?
Al
Those look pretty identical to me. Variations in circuit/batteries/lamp will probably give you a lot of variations in output and runtime. 5% variation is probably typical just in the circuit. Add to that the lamp and batteries and the variation stackup could probably go to 10%
CM
