Surefire Advice
bonvivantmike
I'm considering buying a Surefire. While intimidated by the expense, I want to have the best.
I'm considering either the L2 or the L4. I would like the two-stage brightness of the L2, but I understand it will not accomodate the Pila rechargable batteries, which I want to use. I've read that the other rechargable 123s (that likely would fit into the L2) aren't yet a viable option.
Does anyone have some advice on how I could have a 5-watt Surefire with two brightness levels, be able to use rechargable batteries yet still have the option of disposables batteries when needed?
Thanks, all!
You could get the L4 and purchase McGizmo's 2 stage switch from here. That will give you 2 stage brightness for a smaller package, and the choice of using either regular disposable 123s or Pilas with the light
