Surefire E1L Practical joke
peite
LOL,
You actually bought a E1L and got a L1 with KX1 bezel.
Surefire will make this good im sure of it.
Does the light work?
It shouldnt since it has 2 converters in that setup and thats gotta be bad.
On the bright side if lucky you know have a 4 level light :D
Call surefire,
They will make it good.
And im sure they would want to know about this mishap.
Benny
what on earth is that....
KX1 with L1 tail...and WHAT body?
no way its an L1 body, its too short...unless its cut down and re-threaded?
Crenshaw
one very noticeable mistake: why use a KX1 head with an Z62 switch?
i would love the KL1 head to fit my L1 cree body, the threading does, its just the way the drivers are seated in different parts and the connections what makes it not work, a little mod could work ok, but its a matter of having the correct parts and the right tools to make justice to the light.
Is this for real?? What is that body and where do I get one??
thats why i got milky to make the light in my sig...;)
the switch, has a resistor, so it might make the low, lower...and high, lower, until you press harder..
Crenshaw
cmon you are putting us in so much anxiety, when are you going to put the battery and turn it on??!?! :D
Can you tell us more about the body? Does this light have the 2-stage switching function as the l1?
