I have three G2´s with three different Dereelight drop-ins:
- 3.7-4.2v (current draw 1.2A) has the best output and flat regulation in metallic body light, but in G2 there is "little" loss in output due to plastic, so in longer runtimes like more than 5-10 min continious, you don´t gain that much from high output.
- 3.7-6v module. Current draw 1A. Because of wider voltage range and heat, you get little less output (than 3.7v module) and not-so-flat-regulation with 3.7v li-ion, but i consider this is best option if you looking for output and runtime.
I´ll get ~3 hours with 17670.
0.5A. This is what i prefer instead of floody P60L. 3 hours of
flat regulation output with 17670.
Current draw is same or little more than P60L have, but thanks to Deree´s (and Malkoff´s of course) for using "module base to flashlight body" -heat conduction and therefore this option has
really flat regulation and output.
EDIT: Dereelight modules, as well P60L has some kind of thermal sensor what drops output (=by slowing amp rate?) when there is too much heat in modules, so i have found this safer to run longer for the price of little less output.
I have tested all these and P60L in G2 with metal AND plastic head so in my observations t
here is no help from metal bezel when using these kind of heat conductions.
In
P60L there is ~25% drop of output when using full plastic G2 and i measured that metal head helps "only" 10%, so output drops ~15% in metalhead G2. What happens when you use upcoming P61L in plastic light, which has 2-3 more current draw and much more heat..
Measures made in my own lightbox so they are ultra-scientic, not visual
Personally i prefer throw what Dereelight gives nicely even with lower output. Hotspot is bright, spillbeam is bright too, but not so wide than P60L does, so more light is focused to hotspot.
It is true that G2 is not the best host for led-modules, but i love G2 with different colors so i have to make my compromises between love and heat dissipation
Hope you and others find this informative.:thumbsup:
EDIT:
what kind of lumen output can I expect?
Lumens and luxes are just tools of marketing and sales people. And nothing else.
