youreacrab
- Joined
- Jun 18, 2008
- Messages
- 321
There is so much play in the threads of my G2 tailcap that it is just as likely to go momentary-on from pressure applied to the tailcap (side or vertical pressure) than from pressure applied directly from the actual switch.
Even if i press the switch directly, the entire tailcap will move too.
It should be that it only goes momentary on when i press the actual rubber directly.
Any way to fix this so that the tailcap moves less within its threads yet still maintains its abilities as a twisty?
