GarageBoy
No machining needed like the KL4?
Bypassing what circuit? The driver is in the tailcap. I thought I was supposed to wire it 2S2P?
Energie,
I bought the exact same 14670 battery. It does work, however I have to wonder why the 14670? Why not a 17670 or 18650?
Thanks
18650 absolutely will not fit in a E series body, the L2 is about the same diameter as a E series. 17670 will fit if the body is bored out some using sandpaper, otherwise the protected version will not fit. 14670 would be the next size in line for lithium secondaries:ohgeez:
does AW make protected 17650s? how much is their capacity? around 1300mah or less?
Also would you suggest any other cree led's, or would you stick with the 2S2P?
