Surefire lego problem
FORCETEN
western kentucky
My e2e + lu60 collar + 6p bezel + m61 will not light. I've seen others using this combo, but can't get mine to work. Any ideas?
can you give more details?
what battery are you using? what tailcap? You might want to try the paperclip across the tailend of the body trick to eliminate the TC as the culprit. Have you tested the malkoff in another host?
There was thread last month about a collar not working. Turned out to be a badly done copy. Are you confident about the parts?
Turns out it was a spacing issue. I added a small magnet to the tail end of the battery and it fired right up. The parts were as follows: sf z68, e2e tube,sf adapter from lu60a, 6p bezel, and malkoff m61.
