Nope. There is a 'bit' (I forget how to describe it) that gets in the way. One can dremel it off.Do the M1xx/P1xx series Handgun weapon lights work on Picatinny rails?
No, I don't believe they are. I've never had the ability to try this out, and whilst some part of me is tempted to believe the bezel is interchangeable, most of me is pretty convinced that it, and the W1xx WeaponLights are specific to themselves only.Also, are P1xx series lights full compatible with C/G/P series heads?
So basically no SF Lego with the P1xx series? How about the C-series heads?
From this thread it looks like you can use M-Series heads on the W1xx series: http://candlepowerforums.com/vb/showthread.php?t=193105
Ahh...now I get it. There are THREE version P/W/M and only the M1xx series has the ability to accept different bezels.
THANKS!
If you like I can send you some photos of this mod. I'm not back home until Sunday night so I won't be able to do it until then at the earliest.
Note that the P60L/P61L (and I assume aftermarket LEDs too) do not work in the Nitrolon Series Handgun WeaponLights because the SF123A's are backwards.
On the M11X & W11X type lights it is possible.
I know there is a hex bolt but I was under the impression the remote switches were soldered in place under the cover ?On the M11X & W11X type lights it is possible.
Anyone know the years that SF offered the P, W and M series pistol lights?
