SUREFIRE P6 QUIRK - HELP
RaymondMillbrae
San Francisco Bay Area
Hey folks,
I have a quick question for yall.
A while back I purchased a Solar Force drop-in LED (LIKE THIS) for my SureFire 6P.
http://store02.prostores.com/solarforcestore/catalog/LED.jpg
At $18.00 shipped to my door, it was the best investment I've made in a looooooong time. It totally changed my 6P into a different creature.
But here's my question: Every blue moon I'll reach to turn on my light, and it won't turn on. Neither depressing the clicky switch nor turning the end cap works. But as soon as I give it a small "tap"...it turns right on again.
Wassup with that?
It has not been a problem for me in the past. (A little love tap is all it usually takes to turn it on). But now that I am reading and learning a few things here, maybe I can find a simple remedy for this little quirk. (Something to do with aluminum foil)?
Oh yea...one more thing before I forget. When I first put in the drop-in LED bulb, the light was soooooooooooooooooooooooo bright, that I was amazed by the difference and didn't see anything else. But after coming across this forum, I read that someone saw little "spots" in their beam when they shone it on a white wall.
When I read that, I looked at my beam, and "Sho Nuff"...I had three little dots as well.
Well, the post said that it was a bit of "stuff" that had fallen on/under the Cree bulb, and a quick cleaning would do the job. I cleaned it, and now it's totally spot-free.
Cool. :thumbsup:
Welp...that's it. I'll be looking for your responses.
In Christ: Raymond
Hey folks,
Wassup with that?
In Christ: Raymond
Hi Raymond -- Intermittents are everyone's favorite glitch! . . .:faint: When "tapping" on an electrical whatever -- and it suddenly springs to life -- often times is a good indication that a mechanical problem has reared its ugly head. Several that immediately come to mind are: a not-springy-enough spring (which flashlights are historically famous for), a warped/bent body, wherein the batteries don't always properly align; oxidation of any one of the contacts, which can serve to break overall continuity in the circuit; and last, but certainly not least -- a part, or parts, may be on the verge of breaking and are left hanging-on by a miniscule thread of material -- that, when given a small "tap" . . . mechanically close the otherwise open/intermittent connection.
S-t-r-e-t-c-h-i-n-g a problematic spring sometimes 'fixes' the not-springy-enough spring (short of replacing it). Rolling a flashlight's body (sans lens assembly and tailpiece) provides a quick-and-dirty eyeball test for determining a flashlight body's mechanical linearity (i.e., its FLATness :D). Applying top-quality (what else would a CPFer use? :kiss:) contact spray (or similar liquid from a container and manually applied via "Q-tip") and followed by an oxidation inhibitor "chaser" -- can make a dramatic and lasting difference in virtually everything electrical/electronic where oxidation occurs.
I hope I've helped a little -- and not put you to sleep. :rolleyes:
Best of luck, Raymond - and God Bless. Merry Christmas!
-Clive
Clive,
thanks for the response.
Here's what I did to find/correct the situation.
First I tried to recreate the situation in which the SolarForce Q5 bulb would not work. I found that when in a specific position, and tapped, it would render the flashlight useless. (Only in this one, specific, position).
So I then removed the SolarForce drop-in, and reinstalled the original P60 bulb. Once that was done, I tried to recreate the situations in which the SolarForce Q5 would fail - it couldn't be done.
So by the process of elimination, I deduced that it was the SolarForce drop-in, or it's connection to the host, that was the cause of the problem.
The next step was figuring-out why it was doing that.
Upon some close-up looking and thought, I realized that the drop-in was not "supported enough". When it was in a certain position, and tapped, it would somehow shift out of alignment/contact, and fail. (Tapping it from the opposite position resulted in it's realignment/proper contact, and turned the bulb back on).
So I just reinstalled the original spring (which SolarForce Store told me to remove), but cut a 3/4" inch section from it.
The head could not fully screw on like before, but that's OK, as it's an indoor light and I'm not worried about it being totally water-proof.
The light works perfectly now. No matter what position it's in when I tap it...it stays on.
So a word of caution. Double check everything - completely - before removing your spring. It may be better to not have the cap fully screwed on, than having the light NOT work when you really need it. (Bullet-proof reliability is a must on ALL my equipment).
Kudos, yall.
In Christ: Raymond
If you were to post a new thread, very short, just something like this.
"6P. Non Surefire drop-in. Must be reliable. One word answers only please."
The one word answers would all be the same.
Malkoff
You have your Solarforce drop-in working well now so all is well, but if you ever want to treat yourself and your 6P to something special, Malkoff M60.
Clive,
Thanks for the response.
In Christ: Raymond
Raymond -- You're most welcome. You certainly did a commendable job: demonstrating remarkable investigative talent and "bonafide" Journeyman-level technical repair skills. I'm happy for you, my man! :twothumbs
Hope you continue to enjoy your SureFire_6P + Solarforce_Q5 combo!!! :thumbsup:
Best Regards,
-Clive
Malkoff
Now THAT'S what I call an accurate statement! :D :D :D Great post!!! :clap:
-Clive
