@ Crenshaw: (and others)
I looked a dozen times on the Surefire site today, they really have lots of interesting lights ;)
My idea for my first one is: a C3 Centurion with P90 module, powered by two 17500s. These would last about an hour I guess.
An upgrade could be the Lumens Factory ES-9 (0,85 Amps and 150 Lumens instead of 105 from P90) or SR-9 (with more current draw (1,22 Amps) and 220 Lumens). More than this, and runtime would be TOO short to make it a practical light.
Of course, the C2 is a handier size, but I've come to the conclusion that (at least with Ultrafire) rechargeable CR123s runtime is VERY short indeed (19 minutes!! The 9V lamp-assembly of the 501B draws 1,3 Amps).
By fitting larger batteries, runtime will increase to about an hour with the right lamp (ES-9 draws 0,85A and will certainly make it over an hour, SR-9 draws 1,22A and will run over 45 minutes with good quality 17500s).
Of course, larger batteries require a larger flashlight, hence the choice for a C3 Centurion....
I think the E1E is a very good EDC. It will run 90 minutes from ONE CR123! That's not bad! It's small, and throws out enough light for me. I very much like incandescents, let's see what the Fenix I ordered does...
If I don't like it, I could buy that cute little E1E with a Lumens Factory 3,6V / 0,8A / 50 Lumens lamp assembly, in that case I could use RCR123s in it :grin2:
Just my thoughts for today! I've learnt that you can, indeed, choose two and not three from:
1. small size
2. high output
3 long battery runtime
In the case of the 501B, it has the numbers 1 and 2, but sacrifices number 3 COMPLETELY with a runtime of just 19 minutes :oops:
My Mag 3D is exactly the opposition to it: not so bright, BIG, and has a 10 Hour runtime :D
When camping, and having a car with you, the Mag would be the first choice.... the 501B would be dark, before I had pitched up my tent (this is the good old TNF VE-25.... virtually indestructible, but.... you'll be the last from all people to finish pitching it ;)
Timmo.
1. small size
2. high output
Timmo.
