SureFire9Z - LED drop-in needed
Photonsubstrate
I can't find an LED drop-in made for the Sure Fire 9Z (ancient-I know) I have. Also, I have a couple Tenergy 3.7v protected lithiums and it is too fat to fit in the flashlight body. I thought I might be able to use one with a spacer but no way.
Thanks in advance for any help!
There are lots of LED drop-ins which will work in your 9Z. The Malkoff Devices M60 is probably the best, and most popular.
You can buy them pretty often on the CPF MarketPlace, or watch Malkoff's website for availability.
Can't help with your too fat cells. If they don't fit in the tube, they aren't much use to you.
Most protected 17500's should fit diameter wise. Overall length might be a problem as the earlier P's and Z's had a shorter battery body. If you can go with unprotected and monitor closely, you can use unprotected 17500's which are slimmer and shorter.
Bill
