I’d like to mount an emitter directly to the slug of my copper housing. How do you do it? I’m working with XRE's and XPGs.
I was just going to attach them using their 20mm stars using heat sink paste and screws, but thought it would be more thermally efficient to bond them directly to the heat sink slug.
Ive read that emitters can be removed from the star by heating them in a frying pan. I don’t want to "fry" them in the process though, so what is the approximate heat to use (IE; Med High, Low?) I don’t have an infrared thermometer, so it could be tricky.
I've seen these options for attaching LEDs to a heatsink, generally from hard/thermally good to easy/thermally bad
Reflow soldering
Thermal-epoxy bare LED to heatsink (Thin layer of epoxy!)
MCBCB with thermal paste or epoxy. Again, thin layers.
Note: With the Crees you can isolate the bare-LED bottom contacts by sanding the ends of each, or lopping the corners off the bare LED - that teensy dot on the solder pads is the wire going through the silicon. I've got pictures of that somewhere.
With reflow soldering, you want to get no hotter than the solder's melting point. I used a brazing torch on a metal plate to heat mine. To avoid damaging the LED, 'preheat' it at about 120F for ten minutes to drive moisture out. To apply the LED, melt solder on the heatsink, place the LED onto the solder (tweezers) and let it cool off. Again, just-melted solder temperatures won't damage it quickly. I've put ice on the heatsink a few inches away to cool it from way-hot to more-LED-friendly temperatures. Most solder melts at temperatures higher than LEDs are designed for, so don't dawdle with it hot.
Thermal epoxy's only finesse is getting a thin layer for best results. Thermal epoxy is much more conductive than air, but rather less so than metal-to-metal contact. I get the surface and the LED back smooth and flat. Flat is important; it gives better contact.
Thermal goo requires some way to press the LED onto the heatsink. Prepare the surfaces the same way as for epoxy. Screws on the LED star, or a reflector/optic/whatever pushing it down.
The thermal benefits of reflow soldering only pay off at the highest power levels, and it helps a little bit with limited heatsinking.
