SWAT Lightsaver Lights?
Phaetos
http://www.gunfightersltd.com/Lightsaver.htm
[FONT=Verdana,Arial,Helvetica,sans-serif] PHYSICAL AND MECHANICAL DATA [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] SIZE IN MILLIMETERS [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] WEIGHT [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] PACKAGING [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] LIGHT SOURCE [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] Head Width :32,5 mm Length :122 mm End Cap Width : 24 mm [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] 86 Grams (Without Batteries) [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] Box Or Blister Pack [/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif] 3 Watt Super Bright Luxeon™ Light Emitting Diode (Led) 75 Lumens (100,000 Hrs Lifetime) [/FONT]
POWER SOURCE: 2 X Lithium Cr 123 Batteries (disposable or rechargeable)
FEATURES
‹ Disorientating Strobing Effect
‹ Super Bright 3 Watt LED
‹ Weatherproof
‹ Super strong aluminum alloy
‹ 100.000 Hrs LED life
‹ Total durability
‹ Impact resistant
Good lights or no?
Imported from South Africa?
‹ Total durability
‹ Impact resistant
He doesn't state alloy grade. For instance "6061"
Nor does he state anodizing grade.
If the button is pressed continuously (whether the flashlight is off or on), the flashlight will flash approximately 7.5 times per second as long as pressure on the button is maintained. If pressure is released, the strobing will stop and the flashlight will switch off
I think a momentary on is more desirable than a momentary strobe for most people. Perhaps strobe for LE is important.
