Tactical, Durable, and inexpensive light gift
seanrolsen
Missouri
Hello.
I am looking for a gift for my brother in the Air Force. I had the idea of getting him a nice light from SureFire, but then I found DX.com. There are SO many lights, and I find the specs intimidating.:confused: Can someone recommend for me a small powerful light that will take some abuse? Any help would be great.
:anyone:
Thanks in advance,
Sean
Hard to go wrong with a Surefire, if you can afford it. DX lights are at the low end of the scale.
A good mid-range value would be the Fenix lights (i.e. L1D-CE or L2D-CE if you want to use common AA batteries, P2D or P3D if you want the more powerful (but more expensive and harder to find) CR123 battery format. Plenty of dealers here carry them (fenix-store.com, lighthound.com, seriouslights.com, etc.).
If you want something a little more tactical looking (i.e. more Surefire-like), and are willing to spend a little more, Huntlight and Lumapower have a couple of nice 2xCR123A lights that are still cheaper than Surefires.
If you let us know a little more about battery preference and price range, we can help direct you further.
Here's the one most people seem to like (U2 style clone) and recommend from DX. Add to that about $18 for two protected 18650 batteries and the DSD charger and you have a pretty decent and tough light for about $40... in two to three weeks. OR... spend about $50 on a Fenix L2D-CE, get it in about 3-5 days from CPF friendly dealers and it will use any type of AA battery available (even 14500 Li with L1D body) with multi level outputs making it useful in more situations. I would go for the second choice if you carry only one light or move around alot.
Thanks for the quick reply cage and selfbuilt!
I do not have a battery preference, but I think something smallish would be better than bigish :) I would prefer not to spend more than $100, as this is a gift out of the blue. However, if there is a light that is a $150, but is a really good deal, and a super light, then I would consider it. I wanted to get him something that I think he would like, use, and not buy for himself.
While at DX you can get a lot of great deals, IMHO their stuff appeals more as a source to get lights and components to do modding/customs. While their prices can't be beat, you give up reliability and durability to save money in many cases. Most of their lights that I can think of that would have acceptable durability best lights also run on rechargeable cells, which may be inconveient to give as a gift.That said, the following I've found are my favorite lights from DX:
1) Coin cell lights. Only $0.50 each, the advantage of these is that you can put them all over the place and always have light on-hand. Each should last for a few hours of usable light, which lasts a long time as coin cells are only usually on momentarily. We have these attached to every keychain, and hanging up in every closet and next to every computer for hooking up cables, seeing dark key holes etc. Even if you end up getting something else, It can't hurt to buy 20 of these and use them yourself, or give them away ($10 worth).
2) Ultrafire C2 -- Of all their lights I've tried, I like this one the best -- good throw, and bright spill in the same light, so it's useful both up close and at a distance. Build quality is also pretty good. The one with the black finish scratches fairly easily. The one I linked to is from Kaidomain (a competetor to DX) who has the light with a more durable natural finish. This runs on 2xCR123, or an 18650 rechargeable. This light ($26) 2x18650 protected* cells, and a charger will run a little under $50.
3) Ultrafire C1 Stainless -- this one was just added to DX this morning for $28. It's stainless steel so the finish will be very durable, and very small (not much bigger than the CR123 battery). I recommend running it on a CR123 primary cell. I believe some posters on here have used it and said that it had reasonable build quality and regulation (consistent output).
There are also some options other than Surefire and DX:
Fenix has a lot of great small lights -- you can buy these at Fenix Store in the $40-$55 range. Be sure to get a Cree Edition -- those will be double the brightness of the old Luxeon lights with similar battery life. Lots of their lights run on standard alkaline batteries, all are multi-level, and all have good durability.
Lumapower and Huntlight are also great, a bit more expensive, but extremely high quality -- as far as I know only topped by Surefire. These are in the $50-90 range. Battery Junction has these for sale. They also sell cheap CR123s and ship fast (you get the goods in a couple days, DX can take a couple weeks). I have the Lumapower M1 and it's definitely my most durable light, has great runtime an a 18650 rechargeable (4 hrs high, 26hrs low to 50%), and is my longest-throwing LED light by far, and that's with the textured reflector.
* Be sure to get protected cells if you're giving this as a gift. There's a whole laundry list of reasons I won't get into here. Note that most lights that take both 2xCR123 or 18650 will run a lot longer on the 18650.
+1 on the Fenix L2D-CE. Easy to carry, easy to use, handy selection of levels, and very bright - and runs on 2xaa which your brother can get anywhere and are allowed on commercial airplane flights with no questions.
If you are okay with the Li-ion batteries you might want to consider the "4th gen" VB-16 from CPF member Waion:
http://www.candlepowerforums.com/vb/showthread.php?t=159622
This is a larger than the Fenix and is more "military" in outlook. However, the levels and features are not so much greater than in the elegant L2D-CE.
I'd get him a Fenix; L1D or L2D since they use AAs. He can probably get lithium AAs where he is stationed or use normal NiMH rechargeables.
Dealextreme lights are hit and miss in quality and most use batteries that are hard to find or Li-ions that require him learning a bit about how to use them safely.
Lots of good choices suggest so far.
My first choice would remain the Fenix L2D-CE - classic, elegant, plenty of modes, easy to use, and uses common 2AA batteries. ~$55
For a little more, the new VB-16 from Waion would also be a great choice for 2xCR123A option. I have an earlier generation I modded with a SSC, and this remains my bedside table light. Highly recommended.
Alternatively, the Lumapower M1 or Huntlight FT-01XSE Cree were the other multi-level 2xCR123 lights I was thinking off. They both look more "Surefire-like"
All these lights except the newer VB-16 are reviewed on Doug's flashlightreviews.com. However, you can find the 1st generation VB-16 there under the name BriteStuff Vari-Brite 32L.
I'd suggest you go through Doug's excellent FR site, compare side-by-side, and then make your choice. Frankly, can't go wrong with any of those choices.
If I was going to send a light to someone in the armed forces there are 2 brands that I would choose from. Surefire or Inova. Here are my reasons.
1. Top notch quality and reliability, both are built like tanks.
2. Output is great
3. Lifetime warranty on both brands.
4. Both Surefire and Inova products are made in the good ol' USA
Inova lights can be purchased at you local Target store. If you are going there I would recommend the X0 ($39.99 at Target or $29.99 at LightHound.com) or X03 ($54.99). Inova also offers tactical versions of these lights with a clicky tailcap on line or maybe at a sporting goods store near you. The new T3 ($57.95 at BatteryJunction.com) is out and it is a solid kick butt light. The T1 is also a nice and small light with good output for around $35.00.
I have not purchased a Surefire product that has not impressed me with quality of the tool or light that it puts out. If you have the $$, spend it here. The L1, E1L, E2L, L4, and A2 Aviator are all very pocketable and bright lights.
I have been extremely happy with all of my Surefie and Inova lights and some of my Inovas have taken one hell of a beating (dropped on concrete several times, thrown in a box with a bunch of tools, dropped in water, etc.) and continue to work like new with little more than a small blemish or two.
