Rothrandir
sorry for the long title, it should have been even longer (e-series tactical gripper/tailswitch guard/acessory thing), but that wouldn't fit in the title line /ubbthreads/images/graemlins/crazy.gif
anyway, this is a piece that's been in existance for some time, but just got it back from the annodyzers after about 8 months.
the goal was to create something that made a shroud over the button of my e2e to help prevent accidental activation. this was especially a concern since i am using a modified kroll as the z52's guts. this mod has since become obsolete in the shroud area (with the advent of my r52), but now that is at the annodyzers, and this is kind of nifty too.
and here are some pics, staring out with my extensively modified superfire (there is still more room for modding, which will get done eventually /ubbthreads/images/graemlins/grin.gif ):
here is the tg/ts/at itself:
shot on my e2e from behind(shroud mode):
shot on my e2e(shroud mode):
in use(gripper mode):
closeup in shroud mode:
grip mode with clip:
it also works on kroll based lights (minimag, streamlight, etc), though it doesn't work well, as the rubber is the only thing holding it on. waterproofness is likely affected also:
unfortunately, it doesn't work that well in tailshroud mode, becaues the oring must be removed to get it on (it might be possible to put the oring back on afterwards, but this would be difficult), and it's hard to screw the tailcap in afterwards (though not as hard as i origionally thought it might be). also, when i made it i tested it with the kroll innards, not surefire innards, so it will only work with a clicky mod (maybe with the z57, i'm not sure) /ubbthreads/images/graemlins/frown.gif
in tacticalgrip mode, it works very well. putting it on is easy. just remove oring, put it on, and replace oring. then screw the switch down. again, this only works with the kroll mod.
aside from the modes, the thing itself has 4 4-40 tapped holes, to facilitate the titanium clip in 6 different positions.
2 6-32 tapped holes to facilitate a brass button or similar item (i don't have a set screw for the brass button, so had to dig through my screw drawer to find a 6-32 screw, as you can see it was a little too long /ubbthreads/images/graemlins/crazy.gif
has 2 1/4-20 tapped ports for using camera attachments or similar. it also has a big hole for attaching a lanyard or something of that nature.
the stock e2e clip has also been drilled and tapped to use a brass button. i'm not sure why i'd need a light with 3 brass buttons, 2 camera attachments, a lanyard, and room for 3 clips at a time, but it's nice to know i can if i need it /ubbthreads/images/graemlins/grin.gif
