Tailstanding Manifesto
andrewnewman
Connecticut, US
Of all the features a flashlight might have (Lithium vs. NiMH, Warm vs. Cool tint, Clicky vs. Twisty), the one critical feature that I find most defines a flashlight from my perspective is the ability to tailstand well. Note I said well. A friend once explained that he had coached his wife to run her first marathon and she had run it well. I knew what he meant. He didn't mean she won the speed record. He meant she had energy to spare at the end, was able to enjoy a celebratory dinner out and make it to work the next day without limping. This is what I ask of a flashlight. A little committment to tailstand as a civilizing feature.
Before I continue I should note that many have indicated this to be of little or even no importance to them in their flashlight selection. I have heard that folks never tailstand their lights, they lean them if necessary or put them in a water glass if obliged to have them face upward. For all of you, I respect your positions but your experience differs from my own. I rarely use a flashlight without, at some point in the evening, needing to tailstand if only briefly.
So. let's talk about configuration. Flashlights without flat ends just don't tailstand. Ok, we all know the HDS Clicky / Rotary with flush button will tailstand under duress. It's heart really isn't in it though. The Jetbeam PA40 is another one. If you put the lanyard bean under the short side it will stand reasonably but it would rather not IMHO.
For the lights with flat ends, some are just too wobbly or with too high a center of gravity to count. Some have crenelated tailcap shrouds which inhibit stability. Examples of too wobbly are almost all 2AA configuration lights and surprisingly most 1AA lights. 18650's do better but some are throwers with really heavy heads (e.g. Armytek) and just aren't very stable. 123A lights are more likely to succeed but even some of them disappoint. Even nice wide lights will sometimes fail because they are really tall. I'm not sure I would feel comfortable with a tailstanding TK50 but your mileage may vary.
So what are the flashlight tailstanding champs? Here's the list from my collection:
AAA Category
Preon P0 due to it's magnetic base on metal surfaces only
123 Category
Quark Mini 123
Peak Logan 123 with flat bottom
18650 Category
Zebralight SC600
Malkoff MD2 version 1 with delrin shroud (nice and wide despite tall body)
Multi Cell Category
Olight S35
Fenix TK45 (just about reaching the top of the champ height for the diameter)
Anyone want to add to the list?
My AA/14500 Xeno E03 will tailstand, even with the lanyard attached.
My Sunwayman V10R will t.s..
My older Fenix P1D single CR123 t.s..
As you mentioned, my ZL SC-600 will t.s..
Chris
McClicky tailcap (McTC) for E-series lights tailstands like a champ, and theres plenty of room in between for easy access to the switch.
McGizmo lights look to be the same way as well.
quark regular tailcaps
AAA:
-Lumintop worm is the king of tailstanding AAA lights, but the off to the side key chain hole might put some people off.
-Fenix E05 is a really good tailstander, but you have to align the small ring with the slot just right first.
I have to admit tail standing is not a deal breaker in my book, but theres no denying its very nice to have so long as I can still easily thumb press the button.
My champ right now is the HD2010:
My zebralight H501 tail stands very nicely too.
But it will soon be replaced by this one when it gets here...
Not sure a manifesto is needed, but yes, tailstanding is useful. All of my lights can do it, except for my McGizmo Sapphire, which has a keychain mount I never use. I've thought about paying someone to machine it flat, but I don't care enough because it's not a room-illuminating light anyway.
My Quark AAX tailstands quite nicely. But surprisingly, THE BEST "tailstander" I've ever used is my Zebralight H51w. The ZL H series can, very uniquely mind you, throw a beam in ANY precise direction or angle covering the full hemisphere above a flat surface.
First consider the regular flashlight. You can tailstand it and it just points straight up. You can lie it down, and spin it 360 degrees, but the beam will always be parallel to the flat surface.
When you tailstand the ZL, it will be the same as a normal flashlight lying down (well, actually a bit better being slightly elevated - less beam is wasted against the flat surface). However, when you lie the ZL down, using the clip as a "kick stand" for it to lean against, you can infinitely adjust the clip/kickstand (by rotating it on the body) so the light infinitely adjusts along the 90-degree arc from straight up to parallel to the flat surface. Combine that angle adjustability with a 360 spin, and you can point the beam anywhere within the hemisphere above a flat surface.
BTW, there is no balance or instability here at all. The weight of the clip forces the light to lean that direction, and the rounded back of the tube allows the free rotation. It couldn't "tipover" in an earthquake and really feels like a "weeble that wobbles....." if you try to force it.
I don't know if they intended it work that way, but work it does...
I do not find it a must but given a choice, I would also prefer a light that can tailstand. My E05 is the one I always carry, specially at home, because I can tailstand it anywhere given its perfect base; and I can just lip bite it if needed because of its size.
I only tail stand lights in the evening when I prepare for bed, so I only have a few that do it good and the feature wasn't important to me, but they can do it:
Sunwayman V11R
Zebra Sc51, H51 and H31 (probably all zebras for that matter, but I confirm those models are stable)
Fenix TK45 - also the best anti-roll out there.
Fenix TK70 - just don't brush against it, but it holds surprisingly well on a level table
4Sevens Quark AA/123/AA^2/123^2 regular (the whole regular series)
That's all I can think of...
Can customs be considered?
I will say a Spy007 for the cr123 category and overall category. THE most stable tailstanding light ever.
Tailstanding is a nice feature to have, but it's not a deal breaker for me. My only "serious" lights (more-less stock Solarforce L2 and Jetbeam PA40) can't really tailstand, and I don't see a problem with that. There are zillion ways to improvise and make every flashlight tailstand if it's needed - excluding perhaps tank lights :D
For example, Solarforce L2 derivatives with S8 switch can tailstand well, although their end is nowhere near flat one.
Cheers
Sunwayman V10A, 4Sevens Quark MiniX123, EagleTac D25LC2 (with twisty switch, not with new clicky switch!).
I have a Quark 1xAA tactical with the shrouded turbo tactical cap, which makes the tail fatter than the rest but makes for an awesome stable tailstand. It is currently set up with a diffuser lens and Moon and low as the programed levels. Makes an awesome nightstand light.
I don't care so much about tailstanding of a light in theory, but a utility light like Zebra Light's line of angle head lights really do shine for placing them where you want them and having them put light right where you need them, just as reppans said, they go well beyond tailstanding.
as for my collection, the only un-tail-standing-able is the Surefire E1e...oh and yes, Thrunite Ti.
others perfectly ts...
1) Xeno G5 V2
2) Niteye Eye10
3) ZL SC600
4) Fenix E01
Done correctly, tailcap crenelations can form a tripod, creating the most stability.
A quadrapod has more stability than a tripod, a pentapod has more stability than a quadrapod, a hexapod etc etc etc. The most stable design is a full-circle shroud like what McGizmos have, because that way there is no direction the light can lean which puts the tipping-point closer to the center of the tailcap than the outer circumference of the shroud.
McGizmo designed the perfect tailstanding tailcap when he made it a full circle with no crenelations, and made it shallow enough that the switch could be easily reached without needing crenelations.
