Taking out the batterypack on the N30
Wolf-Eyes fan
Hi guys,
I have just got a N30 HID. Really bright.
I´ve also bought an extra batterypack, but I can´t find out how to take out the batterypack from the light. Can someone please describe it for me?
Best regards
Wolf-eyes fan
At the back end of the light, there is a small black plastic "square button on each side at about the 9 o'clock and 3 o'clock positions as viewed from the back of the light. Turn the light facing straight up. (Gravity helps) Push these buttons in and towards the back of the light with your finger tips. At the same time, you might try shaking the light a bit so the battery will start to pull out. (All my n30 batteries are wedged in pretty tight) The battery will eventually come out about two inches. Just beyond where the buttons are out of the case. Then turn the battery counter-clock-wise maybe 30 or so degrees (as viewed from the back) until it stops. Then continue pulling it out of the case. There are marking on the battery sort of explaining this but you can't see them till you get it out!
