Test/review of Hohm 18650 Work2 2547mAh (Black-white)
HKJ
Copenhagen, Denmark
[size=+3]Hohm 18650 Work2 2547mAh (Black-white)[/size]
Official specifications:
  • Capacity: 2547mAh
  • Max Charge Rate: 3.82A
  • Max Charge Voltage: 4.2V
  • Continuous Discharge Rate: 25.3A
  • Max 80oC | 3.2V cut-off: 35.8A
  • Pulse | Peak6: 42.4A
  • Cycle Life Retention: 500 Cycles (69%), 1000 (58%)
  • Chemistry Type: QSP Li-NMC
The specifications for the battery sound fine and the two cells match very nicely in the discharge curve, but a internal fuse blows at 15A discharge current
The battery is not hot on the outside when the fuse blows.
[size=+3]Conclusion[/size]
The batteries looks fine at low current (That is 10A), but something is wrong with the current rating or the batteries. The overload fuse burns out way below rating.
[size=+3]Notes and links[/size]
The batteries was supplied by Hohmtech for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Thanks for the review on these Hohm Tech batteries. Any chance you a review of their Hohm Tech Base 4 charger in your queue? If so, I am particularly curious to hear about their "Battery Doctor" mode and how it compares to the repair/restore function of other chargers.
I only got the more simple chargers from them for review.
