Lux, yes I'm using 4/5A's for longer run time. The Elephant body is just mm's longer than 3D with the 160mm extension, easily fit 4sx5p 4/5 A's by doing a tailcap mod.
Can fit 16 AA 4sx4p or using 2/3A even more in an old Mag D. Problem with the old (no D in the serial number) D it's threaded differently and FM's 3" head won't fit. Would make one stealth light.
Recently found stored away what I initally thought a 3D kel-lite. Due to it's lack of a mag lite like switch, uses a copper strip to make contact between bat. and bulb (simplicity itself), it's turned out to be a 5D easily holding 4sx6p AA's.
Oh, the possibilities.
Yes, truly need a tripod. Hopefully, someone with a Death Blaster will have one and post some lovely photo's.
The real time effect of this mod is no way done justice by these photos. Blazed this monster next to M@g625 with FM-3H1 and it looked dim in comparison. 11,000 lumens vs 2,2500 L. about 1/4th lumens.
Much like comparing M@g625 side by side with SF M3. Has changed my definition of a Wow light.
Plan to add 17th cell once electronics(soft start, PWM) is worked out.
Jim
LuxLuthor said:
Someone needs a tripod!
You are using those cells for more capacity? The physical size is why the 2/3A cells make it easier to setup a 3D with 16 or 17....but my understanding is 17 cells runs the risk of flashing?
