Action said:
Now this should be a really good discussion! Please guys post some pics and info of what you have done. Could you also throw in some discussion of PWM and how its related but different to the Hotdriver? I don't quite understand the benefits of the mosfet under discussion when compared to the PWM (Pulse Width Modulation?) when compared to the Hotdriver concept. I get them sorta mixed up.
My limited understanding of what is happening is that the mosfet under discussion is used to bypass the Kiu switch (or it is used solely to turn the mosfet on/off) and both offer less resistance and have some softstart capability to keep from hitting the cold bulb with a massive rush of amps + the overvolt and instaflashing. Then again I could easily be wrong...
You're close...
A "plain" MOSFET switch is just ON and OFF. It resides on a circuit board under the KIU socket base. The stock Mag switch no longer carries any real current. It just provides a milliamp or two of current to turn the MOSFET on. When the switch is turned off, it no longer connects the MOSFET control pin (gate) to the B+ side of things and it shuts off via a small resistor from the gate to B-. Sweet and simple. Unless you're trying to REALLY push the envelope of a bulb.
The Hotdriver is a true regulator. It reads the output voltage and adjusts the resistance of a MOSFET onboard to vary the voltage. Since the MOSFET is acting as a variable resistor, it has to dissipate the power that is "burned up" in the MOSFET. The MOSFET can only dissipate so much power before it goes poof.
The PWM soft-starter I mentioned, is NOT a regulator. What it would do is turn a MOSFET on and off several 10s of thousands of times per second. Once the light switch is turned on, the amount of time the MOSFET is ON during each "pulse" goes from almost 0 to 100%. At almost no time is the MOSFET acting like a resistor and dissipating energy as heat. The Bulb would just see an increasing amount of average power as the MOSFET goes to 100% duty. As long as you don't exceed the voltage that the MOSFET and controller chip can take, you could soft-start a 24V bulb pulling 60 amps over the course of a minute if you want.
A PWM regulator is a PWM circuit that reads the output voltage and varies the "duty cycle" of the MOSFET to keep the average voltage that the bulb sees at a certain value. This is a more complex issue and could be a thread of its own. Winny built a PWM based regulator called the PIR. They are rare and expensive and complicated.
