D-Dog said:I saw recently on another thread that using lubricant on the threads of a flashlight can actually wear out the threads faster. Is this true? I am using Nyogel and I want to know if I should just lube the o-ring or both the threads and the o-ring.
If you need to select the proper Nyogel product for your flashlight o-rings and threads (both), the two most often recommended Nyogel products are Nyogel 779zc and Nyogel 760G. If you have an aluminum flashlight, please note the following from the factory literature: Nyogel 779zc ". . . contains special additives for reducing wear of aluminum surfaces."
Also note that many additives that may decrease wear on aluminum threads can actually increase wear on plastic threads.
