Thrunite new lights.
kj2
The Netherlands
Thrunite posting on there FaceBook account;
T21;
" The fifth new model T21, with small size but high lumen, according to the test result, the max output can reach 400 Lumen."
T30S - New model T30S is the update version of T30, which also add the side tactical switch! the max output can reach 600Lumen.
TN11S- New tactical model TN11s also will be released soon, here we can have a quick preview, the appealing point is it add one side tactial switch and two extend tubes. According to the test result, the max output can reach 830lumen.
Note; New switch doesn't fit the TN11
TN31 - No side pic yet, on Thrunite FB account.
ThruNite another big flashlight TN31---the super throw king will be released soon, the longest shot distance is 700 meters with max output 1000lumen.
TN30 -
ThruNite new model with 3 XM-L led flashlight still use the name of TN30, accoring to the test result the max output can reach 3000Lumen. here is the picture with package.
It so hard cathing up with these multi xm-l lights coming out within the next few months and those recently released.
Nice case for the TN30. Looks like throw and flood is balanced with that wide but deep reflector.
These tail end side switches are a wonderfully ergonomic idea; more flashlights should use them.
I hope you're being facetious.
With a side mounted tail end button, we no longer have to "flip" the light 180 degrees to activate the side mounted switch like on the Sunwayman T20CS etc to change modes.
And then flip it another 180 degrees to activate the main tail end switch...
I hope ThruNite improved the battery regulation on TN11S. The original TN11 is ridiculously bright at max, but has horrible regulation.
@gopaitj -you just was quicker with the TN31 pic ;) -I self just saw the pic on Thrunite Facebook :)
:sssh:
TN31, XM-L, 3x18650
TN30
expected cost,
TN11S, $109
T21, $40
T30S, $80
TN30, $240
TN31, $200
TN30
- LED: Three Cree XM-L U2 LEDs with a lifespan of 20+years of run time.
- Max 3000 lumen output using 3 * 18650 batteries.
- Standby: 67 uA; Strobe: 2780 lm. 2hours; Level 1: 1 lm. 1200 hours; Level 2: 38 lm. 75 hours; Level 3: 352 lm.
10 hours; Level 4: 932 lm. 3.5 hours; Level 5: 1580 lm. 2.5 hours; Level 6: 2780 lm. 1.2 hours.
- Working voltage: 8V to 13V.
- Max runtime: 1200 hours.
- Max beam distance: 370 meters.
- Peak beam intensity: 35000cd.
- Impact resistant: 1.2 meters.
- Waterproof to IPX-8 standard, 2M.
- 178.00mm length, 64.50mm bezel diameter.
- Weight: 559.80g without battery.
- Aircraft grade aluminum body structure.
- Premium type III hard anodized anti-abrasive finish.
- Ultra-clear tempered glass lens with anti-reflective coating.
- Momentary forward click tactical switch.
- Strobe mode for tactical and emergency use.
- Smooth reflector for max light output.
- Highly focused beam for maximum distance.
- Tactical knurling for firm grip.
- Streamlined body design.
- Mechanical reversed polarity protection design for battery carrier.
- Intelligent highly efficient circuit board design for max performance and long run time.
- Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and Outdoor activities.
- Intelligent temperature controlled light output for user safety.
TN31
- LED: Cree XM-L U2 LED with a lifespan of 20+years of run time.
- Max 1147 lumen output using 3 * 18650 batteries.
- Standby: 65 uA; Strobe: 1147 lm. 4 hours; Level 1: 0.5 lm. 2000 hours; Level 2: 21 lm. 140 hours; Level 3: 146 lm.
22 hours; Level 4: 366 lm. 9 hours; Level 5: 620 lm. 5 hours; Level 6: 1147 lm. 2 hours.
- Working voltage: 4V to 13V.
- Max runtime: 2000 hours.
- Max beam distance: 700 meters.
- Peak beam intensity: 75000cd. :ooo:
- 201.70mm length, 79.00mm bezel diameter.
- Weight: 452.80g without battery.
OMG OMG OMG! i will be one of the first to get a TN31. 75000cd?!!?! .. if i was a XM-L U2 i would pray to GOD i was not put in this light.
I like that TN11 :D -75000cd damn! :)
Only, I thought that an XM-L had a max of a 1000lumens, or am I wrong?? (I could be..)
