TIG Reccomendations?
StrikerDown
NoKal
Looking to get a TIG rig! I'm tired of paying someone to screw up my stuff when I can do it myself.:eek:
Anyone have a box they are happy with or maybe as or more important is there any to shy/run away from?
Mainly I want to be able to weld smaller items, flashlight or handgun sizes. Aluminum, carbon and stainless steels with more precision I can't get with the MIG, or Ox/Ace.
Thanks for your help:wave:
I'm not a pro by any stretch but I wanted a machine that could do aluminum as well as steel and could travel if need be and run off 110v in a pinch. My Dynasty 200DX did all that and, despite our shop having several other larger tigs and a couple migs it's become the go to machine for aluminum or fine detail work because it's square wave is so nice. Small, compact and pretty sophisticated and since I don't do big stuff it more than covers anything I need. Love it.
Here it it on the cart it made (with the cooler which is nice for aluminum):
Sakurama, Thats a damn nice set-up!!!:ooo::naughty:
I have a Miller syncrowave 200 and it'd done what I've needed it to do.
Doesn't get used as much as I'd like...but DAMN is it nice to have when I need!:thumbsup:
The Dynasty 200DX is a very nice machine - about $4500 with water cooler. I went with a HTP Invertig 200 with water cooler for $2895 & it has been flawless: http://www.htpweld.com/products/tig_welders/tig201.html
You'll need to choose either hand control or foot control - I went with the CK Rotary Amp Control years ago & have never looked back: http://www.ckworldwide.com/amperage_controls.htm
Miller, Lincoln, HTP, etc. all make excellent inverter TIG's. Try them & see which one you like. Whichever way you go, get the water cooler & water cooled torch - much smaller, lighter, easier to handle & cooler.
Anything Chinese, anything with no name or no support. One eBay ad reads "TIG Inventor Welder" ... maybe that should be inverter :nana:
FWIW, there are still many transformer machines available, like the Miller Synchrowave. The technology is older, the units are large, power consumption is high, and the ability to control & shape the arc is limited (as all AC welding, like aluminum, is done at 60 Hz).
Inverters, like the Dynasty & the Invertig 201, give much more arc control. The Dynasty is an advanced inverter design that will do everything except cook your dinner to order :)
Europeans invented welding inverter technology & both Lincoln & HTP have Euro factories that build their machines. In a Lincoln machine, look at the Invertec 205. Like the Miller Dynasty, the Lincoln inverters are very small & super light weight.
With all the emphasis on inverters, one can sometimes find a nice, used transformer machine (like a Synchrowave 200/250/300) at a bargain price. Or a Lincoln Precision TIG 225/275/375. If you decide to buy a transformer TIG, especially a bigger one, make sure you have an outlet that can supply the machine. They are physically large, pretty heavy, need a lot of juice, but produce a nice weld & they last forever.
Thanks Barry. I need to do some research, looks like a lot to learn before I make a decision... I hate buying something then finding it isn't suited for what I need, Or has expensive features I will never use. Looks like lots of different options to choose from with a TIG.
You can break it down to this ...
Transformer or inverter?
If you choose inverter, simple (HTP201) or fancy (Dynasty 200DX)
I choose the HTP201 as it does what I need and doesn't cost a ton. Lots of users like the D200DX for the many available settings.
Thanks again Barry, Your machine looks like the best way to go, especially cost wise. Most everything I plan on using it for will be small parts probably low power requirements so the water cooler option would not be a necessity, and could be added at a later date if it became necessary... I think!
Is there one type shielding gas that will work for aluminum, SS and carbon steel, or is there a benefit to using different mixes?
Also above Sakurama mentions that "it's become the go to machine for aluminum or fine detail work because it's square wave is so nice". Is this a feature on the HTP201? If not would it be handy to have when welding up, say a 1911 thumb safety lug?
Square wave doesn't get a lot of press today, as that technology was invented about 25 years ago (by Miller). Not sure if the HTP201 has it or not.
Argon works for most every metal, and lots of welders use only argon for TIG. I've found (as have many other people) that 75% Helium/25% Argon is an awesome mix for aluminum, especially with a mid sized (200A) machine. The puddle forms much more quickly & wets out fast - but, the puddle is more fluid and can be more difficult to control if out of position.
A good review on the HTP201: http://hre.com/HTPInvertigreview.html
The air cooled torch will get you started, but I'm betting it will grow old fast. In addition to the discomfort (heat) of the air cooled torch, it is huge compared to the water cooled version. The water cooled torch can get into tight areas that will be a challenge with the air cooled.
I still give myself a smack in the head every once in a while :( I typically check the local craigslist daily. The one day I didn't a Dynasty listed for $1200 and I missed it! I'm happy with my Lincoln 175 Pro that I picked up locally for $600. The unit had never been used and was sitting in a body shop. I know have a bigger argon tank on the machine, it was upgraded for free after the first one I purchased had the wrong or contaminated gas. New Welder + New to Welding + Bad Gas = Rip all hair out!!!! Thanks god my buddy is the local welding instructer and had a spare tank to try!
I will probably be using it for steel primarily. That is all I weld currently with MIG and/or Oxy/Ace so It sounds like Straight Argon is best. Is the H/75%-A25% mix usable for steels or just AL?
Mac, I remember when you posted getting the Lincoln... I was so jealous! Found this one on craigs: http://sacramento.craigslist.org/tls/2357859327.html
Pablo, Very cool. Looks like a very strong joint. Is that actually welding the Aluminum or is it more like a solder/brazing process?
You can use it on everything ... but:
It costs more than argon
Arc starts are harder as they require higher voltage to establish the arc
The puddle is hot, fluid, and more challenging to control than an argon puddle
The helium is lighter than air, requiring more CFH flow when welding in most positons (flat & horizontal being the most common). When welding overhead or vertical, the gas rises to the joint & less can be used.
If you only want to use one gas, get argon.
Thanks B,
Very good info. I would hate to get started with the wrong gas... not enough hair left as it is!
Going to start hitting Ebay and Craigs!
I started this thread about a year ago and I have been saving my pennies (and bigger) ever since. When Gold hit $1800 an ounce a while back I dug out a bunch of old stuff and went to the gold guys to get almost there!
I was able to pull the trigger today and she should be here in about a week!
http://www.usaweld.com/ProductDetails.asp?ProductCode=70221-12.5
I ordered on the phone so I could specify the #9 (Small) torch because most of what I plan on welding will be smallish parts, Also when I save up a little more I can get the water cooler and a #20 torch that uses the same cups, collets, etc. and it will be able to handle the full power of the 221 and stay cool too!
Pics to follow when I get them.
Thanks again to all for the info, you guys are the best.
Christmas in May :)
You'll really enjoy that machine. I spoke with Steve Holzer (tech support/sales/repairs) & he said the 221 has many of the features of the Miller Dynasty. At only 41# (about 19 kg) it is easily portable AND it will run on standard 120 volt service. That means you can do portable TIG repairs without having to worry about hooking up to 240 volts.
The water cooler is a must if you weld thicker aluminum/stainless/cast iron/etc. & the WC torch is tiny compared to the air cooled models. I purchased the Rotary Amp Control that mounts on the torch handle (also available from HTP) & haven't used the foot pedal in years - probably never again will.
Some owners have good success on aluminum with 100% Argon but I used 75% Helium-25% Argon. The arc is much hotter & will make your 221 perform like a 275 amp machine when you need the extra heat input.
My Invertig 201 is already starting to feel inadequate :devil:
No Christmas but my birthday was the 9th! :nana:
I didn't order the dual voltage model it's another 500 plus, That plus the WC puts it real close to the Dynasty.
The WC may happen if it gets too hot with the little stuff I have planned for it... Looking at lots of practice before I do anything serious though so it will be a while.
I was mig welding something the other night and my flow meter started acting up, blowing Co2 out the vent hole, so I ordered a Co2 only meter at the same time as the TIG. First problem with my Miller MIG in 25 years of (very) light use.
Getting anxious... again! :naughty:
