Tigerlight?
Polar
How does a Tigerlight compare to a surefire M3 as far as brightnesss?
TIA /ubbthreads/images/graemlins/help.gif
With the higher intensity bulb in the M3 I would say they are pretty close, but the TL will out throw the M3 because the TL uses a smooth reflector.
Correct me if I am wrong here! Tigerlights are rechargable and come with pepper spray canisters?
Tigerlights are rechargeable.
There are two models, the Tigerlight FBOP does not have pepperspray dispenser and might be the right choice depending on your local laws. It is also shorter [8"] and a little less expensive.
The regular Tigerlight does have a dispenser, but I think you need to buy pepperspray cartriges seperately.
http://www.tigerlight.net/
Sorry about digging up this old thread /ubbthreads/images/graemlins/crazy.gif but I'm getting the idea that I could consider the TL as a 'budget' M3 with similar throw.
Yes yes? /ubbthreads/images/graemlins/tongue.gif
The TL will out throw a SF M6. At less than 75yds, the M6 will kick butt on the TL.
tinyE, I don't have a M3 to compare with.
I don't think the TL is as rugged [durable] as an M3, but it has a couple advantages: cheaper to buy and cheaper to operate [rechargeable battery].
TL doesn't provide lumens figures but my guess is that the M3 HOLA with fresh batteries is pretty close to the TL in output. The TL will out throw the M3 HOLA because of the smooth reflector it uses.
If you prefer the smoother output of the M3 you can buy a UCL-LDF lens from flashlightlens.com. It will smooth out the TL beam [at the expense of losing some throw].
That's what I was thinking on the initial and operating costs as well.
I love my my SFs, but they may be a little more rugged than is required for my non-demanding uses (i.e. - shining it at the trees to see how bright it is).
Thanks for the confirmation.....I might just try it.
[ QUOTE ]
tinyE said:I love my my SFs, but they may be a little more rugged than is required for my non-demanding uses (i.e. - shining it at the trees to see how bright it is).
[/ QUOTE ]
/ubbthreads/images/graemlins/grin.gif I understand ... I can confirm that the TL is definitely well suited to that task /ubbthreads/images/graemlins/grin.gif
Edit: The only question is which version of the TL to get. Do you ever feel the need to pepperspray the trees? /ubbthreads/images/graemlins/icon15.gif
[ QUOTE ]
[/ QUOTE ]
I am not sure an M3 could take a hit from a baseball bat and still work or get thrown across a parking lot. I know the TL can as you can watch the video on there web site. /ubbthreads/images/graemlins/grin.gif
Naw.....I'll stick with the 8"...
I spend so much time looking into the wrong end of the lights anyway (just to see how bright they are), that I would probably stare into the spray outlet just to see if it really hurts /ubbthreads/images/graemlins/thinking.gif
Got the TigerLight FBOP. The second gerneration lamps are really, really ugly, with the batwings and other strange anomolies. Its brightness and throw is amazing, however. Feels really solid in my hands.
The main reason I purchased the TigerLight was mostly for novelty and show. So why oh why didn't I buy the OC version "The light with a bite" instead???
[ QUOTE ]
[/ QUOTE ]
Because it's three inches longer? Also not to be discounted is the fact that no one I know would want to be sprayed in the face with OC for the sake of novelty or show. /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/hahaha.gif
I'd have to agree with the LA quality assessment, they are pretty poor. I even got a new (3rd Gen.?) LA with my TL, and while it is better, it still leaves plenty to be desired. Someday TigerLight will get this figured out and the TL will become a fully realized and mature product. I just hope that they will still be reasonably priced when this happens.
Anyway, I still love my TigerLight, warts and all. The throw and output of this light is amazing. For the money, I don't think there's anything out there that can touch it.
Peter
LitFuse, I would never ever use OC for show. /ubbthreads/images/graemlins/banned2.gif It's illegal to use it in any manner other than for self defense. When I was considering which model to buy, I planned to switch the OC canister for the inert gas training canister if I decide on the OC TigerLite. Here in New York, it is prohibited to purchase OC from another state. If I got the OC version, I will need to hunt for proprietary TigerLite OC canisters within the state.
I though it would be a real surprise to show my friend who is into LEO stuff the light. Show him the beam, then tilt the light 90 degrees, point to the "Caution Pepper Spray" warning, and discharge, then to his surprise it was just inert gas. But I guess that's mean.
You were right though. I finally decided on the FBOP because it is 3 inches shorter. Also, I did not want to be caught by police with OC concealed in a light in the wrong place at the wrong time (things are different in a post 9/11 world). /ubbthreads/images/graemlins/twakfl.gif
I'm still quite happy with the light. Not my mother though...
I have both the 8" and 11". I have 5 cans of pepper spray and have yet to load the first can after 6+ months of ownership. I did play with the inert spray and had fun with the guys at work. My 8" spent 3 days outside in the heat and rain last week after my son threw it out the back door (handicapped). I found it as I was cutting the grass, nearly ran over it. Oh yes it still works fine.
I pitched it to the Sheriff's dept. but they are going to stun guns and getting rid of their pepper spray.
I know it's not M3 or M6 beam quality or engineering but it's bright, tough and hasn't used any 123's after 15+ hours of use at about 400-500 lumens. That's (240) 123's worth of use in a M6. I could buy two more Tigerlights just in battery savings so far, not to mention the longer lamp life.
In the M6's defense, 500 lumen compact flashlights aren't designed for extended use and the smaller size has a distinct advantage for tactical use. The Tigerlight is slightly fatter than a Mag D cell. Aesthetics, beam quality and size make the M6 a clear overall winner until you factor in cost, initial and on-going.
The video on the Tigerlight site is impressive as mentioned by jtivat.
Wow, DieselDave, you got both! It must be nice to be able to choose either one: I think I'll have a little fun with the guys today. 11" it is. Or: Don't need the OC or the extra length and weight today. 8" is the flavor of the day.
I wonder if I can just purchase the 11" body from TigerLight CS.
The OC cannister for the Tigerlight actually isn't proprietary. You should be able to use one from just about any manufacturer as long as the top is compatible.
[ QUOTE ]
jtivat said:
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
I didn't mean to imply the Tigerlight was poorly built, it is quite solid.
I was refering to the shock isolation feature in the bezel of the M3 Combatlight. The deep knurled finish on the M3 also "looks" like it might be tougher, but I realize they are both mil spec type 3 HA, so I might be wrong on that.
In any case, I do not intend to hit either with a baseball bat or throw them across a parking lot to find out.
