TN12 driver failure
CaptainRogersUK
Yorkshire, United Kingdom
I seem to be ahving a run of bad luck with new torches :(
After buying a TN12 fro illumination supply in late november, mine's been used twice but now It fails to power up. After checking online I notice the TN12 had issues with it. It is not really worth sending back due to customs and clearance :( But generally speaking how reliable are the TN12's are the smaller lights by Thrunite.
Thanks in advance
I seem to be ahving a run of bad luck with new torches :(After buying a TN12 fro illumination supply in late november, mine's been used twice but now It fails to power up. After checking online I notice the TN12 had issues with it. It is not really worth sending back due to customs and clearance :( But generally speaking how reliable are the TN12's are the smaller lights by Thrunite.
Thanks in advance
I sent my scorpion in to thrunite, directly to factory for repair on a circuit which went bad on first start up, shipping was not expensive and they got it back to me pretty quick in the end, its been faultless since.
Hello Sir:
Do not worry. we have Service support in Europe to help you!
Regards
ThruNite.
Are you sure it's not the switch? I have a TN12 which came direct from Thrunite with the switch retaining ring not property tightened down. I took the whole switch out and reinstalled it and it worked fine after that...other than the less than stellar twisy level adjustment. You may indeed have a circuit problem, but check that switch first, I believe it is a recognized (at least among recent users) glitch in an otherwise decent little light.
