highlandsun
Showing off my ignorance here... The transistors I'm currently using for my LightWasher upgrade are in plastic TO92 cases. It seems to me I'm abusing them pretty badly; in one case I burned my fingertip when I touched the case.
The deal is this - I want a current source that varies from 0-350mA (or 0-700mA) where Vc is +12V, but the load may only need 3V. E.g., if I have only one Luxeon connected. In this case, the transistor is dissipating the other 9V @ 350mA, which naturally makes it heat up a lot. If I have 3 Luxeons connected in series, then of course they soak up most of the power and the transistor is dissipating less.
But I want something safe for the 1-Luxeon situation, and I'm not sure what I'm looking for. I think this calls for a TO126 or TO220 case, but what specs should I be checking to tell me that this is in the safe zone?
I'm also thinking about using a MOSFET instead of a BJT; since I want to have the option of controlling the current source using my 10K slider pot. Since the slider basically acts as a voltage divider, that would seem to be better (a voltage-controlled device) overall. Make sense?
