Chris M.
It finally turned up this morning. Here`s an informal load of waffle about it.
** Supplied with batteries and a Lanyard, and it has a recessed fold-out "split-ring" in the tail to attach it to.
** Very good build quality. The lens is very thick, probably Lexan, and sealed with 2 o-rings that have plenty of silicone grease applied so it`s wquite easy to turn. It`s quite smooth though so one-handed operation could get tricky.
The body feels like the same stuff Tektite use- ie, ABS, and also feels extremely solid. It`s not going to break easilly. I may try to break it later, depends on how drunk I get
** The four white LEDs are mounted through a black plastic "holder" which keeps them in alignment and does seem to reduce some side-spill that would shine in your eyes. They are directly connected to the batteries with no resistors at all.
When I first turned it on it was very bright indeed, looked like twice as bright as its nearest rival- the Trek-4. But then.....one of the LEDs started to turn sky-blue, quickly followed by another. And the other 2 started to look distinctly blue (and overall dimmer than they were initially) after a minute or so.
I havn`t had chance to do any measurements on it yet but I expect the direct connection is not a good idea, they seem horribly overdriven. I wouldn`t be surprised to see 300mA going through that board in the first few moments- the back of the LED board was very hot as was the top battery in contact with it. I also noticed the lens beginning to fog up, not sure what from. Opening it up afterwards seems to have let out whatever it was, as it doesn`t do it now.
I`ve been playing round with it a bit and have probably taken the initial kick out of the "Maxell Super Alkaline" cells, as the LEDs now do not turn quite so blue. Maybe this initial overheating will not be such a problem.
I`ll try different types of batteries in it soon, I don`t own any good NiCd or NiMH, maybe it`s time to get some- their lower initial voltage may be kinder on the poor LEDs.
**On to the neat bit- the Tritium Glow elements. There are two of them, potted into the head (see the photos below). They are smaller than the ones used in the GlowRings, just 8mm long and about 1mm wide, and are green ones. When it gets dark I`ll take some photos of it, my old v/c has a good low-light gain setting that actually can see the glow from those things.
Want to see? OK....
<center>
</center>
Questions? Thoughts? Comments? More photos to come after dark.
Want to see? OK....
<center>
