I've been looking to build some canister dive lights. I need to build two because my dive partner is my son.
Use the head and module from this: http://www.kaidomain.com/ProductDetails.aspx?ProductId=10719
I think module is the same as discussed here: http://www.candlepowerforums.com/vb/showthread.php?t=284903
Plan is to use only the tail cap section, switch removed, epoxied (JB weld) to the head.
Put this http://www.mcmaster.com/#orders/=8598e0 in the switch hole.
Seal the head with O rings and silicone. Build a basic ABS canister and use some 18V battery packs built from these http://www.harborfreight.com/18-volt-replacement-battery-90121.html. Probably just a toggle switch. Maybe reed switch on the light head if I can find one that would fit.
I've built lots of bike lights before, halogen/ni-cad systems. This is my first LED/waterproof build.
Thoughts?
Thoughts?
