Turning a motor into a grinder.
*Out There* (Irvine, CA)
Hey guys, I've got my 3/4hp baldor 1725rpm motor that I want to put a 5/8" mandrel on to use a paper wheel sharpened for knives. Is there a better reasonably priced solution to this, such as a belt driven spindle. I cant seem to locate a spindle, I guess they're out o fashion. Anyways should I stick with a set screw on mandrel or can someone recommend a belt driven spindle or other option thanks.
I built a wire brush machine, but the arbors could just as easily hold polishing wheels.
attachment.php
The wire brush is belt driven by the motor mounted near the floor.
The arbor shaft is a 36" long piece of TGP shafting, threaded on each end. The shaft is supported by ball bearing pillow blocks.
The shaft drive sheave fits over a keyway on the shaft.
Not at all hard to make one like this, although I'd go with larger diameter shafting the next time. A 1.5" shaft would be about right for the 14" wheel being turned.
That's a nice rig Barry, unfortunately I don't have steel laying around or the parts or a weldor. Thinking of something much simpler and smaller, probably run 10" wheel max with very little load, power strolling knives basically.
