Twist Light Stopped Working, How To Troubleshoot?
blan
Well I know that to troubleshoot a clicker you connect the body of the light with the negative side of the battery inside the tube and see if it lights up or not. But you can't do this with a twister that only open through the top.
How can I troubleshoot it? It just stopped working one day as if the Cree had burned out but it's impossible with the usage I have given it. The light is Ultrafire C5. I rather try to fix it before I write it off as a loss.
I got the Ultrafire C5, I have to twister it tight to on the light, one day it die, I open it and see the electronic board is broken because I twister it too tight.
