MrAl
Hi there,
I've successfully used two diodes to fool a NiMH charger
into thinking there were two cells in the charger instead
of just one. The type of charger was an RS charger.
Before using the two diodes, i tried both 1 ohms
and 1.5 ohms as well as a direct short for one cell,
and all methods failed...the charger would 'pulse'
the cell with a high current but only once per every
two or three seconds and only with a short pulse.
The only thing that worked is two diodes in series.
I used 1N4006 diodes for the test, but they got too hot
because the charger puts out 1.2 amps and the diodes are
only rated for 1 amp, so im recommending 1N5400 (or similar)
diodes instead.
As mentioned, the two diodes are wired in series so that
the total voltage drop is near 1.5 volts. The voltage
is fairly constant, so to the charger it looks like a cell
/ubbthreads/images/graemlins/smile.gif
I cant say for sure if this will work with every charger
out there, but it's worth a try.
I originally wanted to do this because when allowing the
charger to charge two cells in series it shuts off once
only one cell reaches it's full charge. If it's only
charging one cell that cell has to get full.
A drawback to this approach is that, at least with my
charger, if i want to charge two cells i'd have to wait
twice as long (put one cell in each side with a dummy,
where each side normally does two cells) because the
current is only half when charging four 'cells'.
If anyone else tries this please report back here with
your charger name and model number (if you can).
Thanks!
If you report back here any results (good or bad)
your contribution will be used in the future when
other people visit the site to determine if they
can fool their charger, and how to do it.
My charger is RS Cat No. 23-043
Take care,
Al
PS Also tried a single diode and that didnt work either.
diodes instead.
Thanks!
Take care,
Al
