How much did they charge you for shipping to the Netherlands? It looks like you have to create an account to know your shipping charges :thumbsdowHi,
I've just received my Smart RL-318R (...)
Had to wait 2 months before it arrived from bikeparts4me.de but this was not their fault but the mailman's.
Nothing new three months later: neither the 317, nor the 318 are on the Smart website.Strange enough, the website of smart does not mention this new light.
Really the only thing I'd fix at this point is that dang clip. These things have to have more secure clips! If I clip it onto the strap on the back of my seat bag, it just goes flying when I cross railroad tracks or similar. One ride, I had to go back for it three times. The good news is that nothing broke, and it was easy to find.
I've started to slip an Oring over the front lens and around to capture the scooped part of the clip after it passes through the strap it is clipped to. It works OK, but is an annoying kluge. I can' think of several ways to make this clip better without adding much expense.
Any idea what broke it? I'm assuming that it was a winter pothole that also knocked a filling out..
I've got one that gets a fair bit of use. My only complaint is the tendency of big bumps to randomly turn it on and off (another testimony to Illinois roads). I can't decide if I should just replace it or wire in a separate switch and disconnect the current switch. Is there something better on the market?
how many taillight models does L&M have? I see a Vis 180 that sells for around $90. It has a lithium battery and charges with USB. That's a little fancier than I was thinking of.
Actually, I was looking at info on a Cateye that runs off of a single AA cell.
http://www.cateye.com/en/products/detail/TL-LD630-R/
I would need to know if it can mount to a seatstay, though.
I've had good results with a Cateye LD-1100 on my commuter. Two AA cells, lots of LEDs... even some facing to the sides. Not bad. Of course, it's not listed on Cateye's site anymore.
The SuperFlash that I'm considering replacing is on my go-fast bike, so the LD1100 wasn't under consideration anyway, but I do like the build quality.
