Two resistors in parallel. Ohms cut in half?
Orion
Bronze Member
Missouri
If you put two resistors together in parallel, are their ohms, for each, cut in half?
To restate, if you have two 1 watt, 4 ohm resistors, put them in parallel, do they now have a 2 ohm resistance each, or would I then have a 2 watt, 2 ohm resistor?
Thanks!
No.
Two 4 ohm resistors in parallel have an equivalent circuit resistance of 2 ohms.
formula for parallel resistors:
1/R(t) = 1/R1 + 1/R2 + 1/R3 ...
where R(t) = equivalent TOTAL resistance
So, 1/4 + 1/4 = 1/2 so R(t)=2 ohms
Depends. If you twist the leads so they are very close together, your power dissipation capabiltiy goes down, so 2 1W resistors very close together might only safely dissipate 1.5W. If they are spaced apart a bit, and have some airflow/airspace, then you should be equivalent to a 2W resistor.
One thing to note, it's best not to exceed 1/2 of a resistor's power rating for safety purposes. So, it's best not to exceed 1/2W of dissipation for a 1W resistor.
Well, I already have some 1 watt resistors but needed 2 watt resistor. I'm just going to the electronics store and buy a package. /ubbthreads/images/graemlins/icon3.gif
Well, the 2 watt resistor is too thick for what I was wanting to use it for. /ubbthreads/images/graemlins/frown.gif
Should I go with the two 1 watt resistors, . . . . .or maybe three [unless that's overkill].
total resistance it equivelant to the reciprical of the sum of the recipricals. (gotta love the definition).
If the resistors are the save value it is easy.
2ohm + 2ohm = 1 ohm
3ohm + 3ohm + 3ohm = 1 ohm
and so on..
and I will leave it at that.
Jeff
Well, crap. This is more involved that I had hoped. I've got two 3.9 ohm 1 watt resistors and a 2.7 ohm 2 watt resistor. The two 1 watt resistors probably won't work becuase of their limitation, and the 2 watt resistor doesn't fit. The 2 watt resistor at 2.7 ohms is the value I need. /ubbthreads/images/graemlins/banghead.gif
I'm beginning to think that I'm not going to be able to do this. TWOL, two CR123 batteries, . . . . . . . anyone have a VWOT? /ubbthreads/images/graemlins/icon3.gif /ubbthreads/images/graemlins/jpshakehead.gif
so what value of resistance are you looking for... rangewise?
the 2 3.9ohm in parallel should be a little under 2ohms I would think so you need 2.2-2.5 ohms instead?
I agree that two 3.9 ohm resisters in parallel won't be enough. I'll probably have to go find some resistors in the low 5's and parallel them together. I considered two 4.7 ohms, but even a little more would be better. I don't want to push this thing too hard. It's a small sized light that would probably heat up too quickly if I got close to that 1A mark. Probably wanting to have the output of 700 mA. Give or take, depending on what I can find in the electronics section.
just if anyone dosent know th formula out there. I just recientally worked it out.
lets say you have 3 resistors. 10ohm, 22ohm and 47 ohm
10/1 22/1 47/1
take the reciprical of each
1/10 1/22 1/47
get a common denominator
10*22*47 = 10,340
multiply the top of each number by the bottom of the other numbers..
(1/10) 1*22*47 = 1034/10340
(1/22) 1*10*47 = 470/10340
(1/47) 1*10*22 = 220/10340
add them together
1034/10340 + 470/10340 + 220/10340 = 1724/10340
take the reciprical of that.
10340/1724 = 5.99ohm
VERY handy formula, albiet you need a half page of paper to figure anything out, but it works.
Jeff
A simpler way to express it would be.....R=AxB/A+B. If resistor A=10ohm and resistor B=22ohm, then 10x22=220 and 10+22=32. So 220/32=6.875ohm.
Add a third resistor 47ohm and 6.875x47=323.125 and 6.875+47=53.875. So 323.125/53.875=5.99ohm.
Remember that the final resistance must always be lower than the smallest resistor.
/ubbthreads/images/graemlins/thinking.gif /ubbthreads/images/graemlins/icon3.gif So, . . . . . I think the two 4.7 ohm 1 watt resistors might be best. /ubbthreads/images/graemlins/blush.gif
two 4.7ohm 1W would be about 2.35ohm 1.75W (if mounted together), that should work. I forgot the equasion LONG ago, durring some of the endless hours at work I worked out the previous formula. yours is easier. will it work R=A*B*C/A+B+C ?
Jeff
/ubbthreads/images/graemlins/smile.gif I sure do hope so. If all else, I'll mod something with more room and just use the 2 watt resistor. I have a Legend LX that would work well. Thanks for the help, guys!
[ QUOTE ]
[/ QUOTE ]
I don't think so.
Three 30 ohm in parallel gives you 10 ohm resistance (yes?) and the equation above works out to 300. I'm a bit sceptical about my thinking here since it is off by an exact multiple of 10. /ubbthreads/images/graemlins/thinking.gif
It has been WAY to long since I pretended to learn this stuff!
[ QUOTE ]
[/ QUOTE ]
No.
The correct expansion for 3 resistors in parallel is:
R1*R2*R3 / (R2*R3 + R1*R3 + R1*R2)
I would measure the resistance also, it is very rare but once in a great while you get a resistor that is defective and out of the range specified by the % color band on it. I have learned in life not to trust things that I can easily test instead, that way there are less suprises.
