UK 2AAA - My latest experience
thunderlight
Phoenix, AZ
Hi,
Despite previous problems with my UK 2AAAs, I decided to try again. I like the form factor and simplicity and I want a small plastic LED and/or incandescent light that uses old fashioned tubular batteries.
I purchased the safety rated incandescent model. My previous models were essentially identical, but they did not have the safety rating. So far, so good. I have used the xenon lamp assembly as well as the LED from my other models and have not experienced any of the previous issues.
As a reminder, in the past, there appeared to be some peculiar short that heated up the batteries. The rear of the battery compartment became extremely hot. Other individuals reported similar problems. I have not experienced that with this model SO FAR.
I like this model in both the incandescent form and the LED form, so I will probably use both. I realize that the safety rating no longer applies when I use the LED. It should be noted that all the evidence pointed to a shorting problem in the wiring. This was not an issue of venting or similar, since the result was the same for alkalines, rechargables, and lithium AAAs.
Thanks,
Bob
Those were nice little lights. Only shorting possibility I can think of is the clip like contact at the front. You might also like the Princeton Tec Blast.
Had one of those die quietly in my sock drawer once; the polycarbonate bezel died of old age in climate-controlled comfort. What the heck?
Pretty sure it's a materials problem, but they won't replace it.
