Some people use WA1160 for short run which is good improvement in brightness but you need to bend bulb pins in order to fit.hi,
looking for some Ultra Stinger Mods.
did a search and it seems that the last time someone has posted anything on the Ultra Stinger seems to be 3-4 years ago. anyone done anything with these since then?
thanks,
brandt
Try 5671 or that 4.8 volt wa bulb.
I have one modded with a WA1160. Very bright.
However, you must replace the plastic window with glass, which is not easy. The plastic will melt after a few minutes.
Big thing is that the switch is just not up to the task. I am on my third switch and am going back to the stock lamp. Still makes a great light.
Mark
Interesting. I wonder if the switch can be modded for lower resistance?
Bill
Mark
is it OK to leave a charged light on the charger constantly? and if not, can i just leave it in the charging cradle un-plugged? or would that drain the battery?
thanks again for all your help.
brandt
What gave out. The switch fail, or heat from bulb melt switch? Wonder if one of those mica shields that ginseng sold several years ago would work.
Bill
Bill
