Definitely the 5 Watt, probably the high dome, like Mr. Bulk's Space Needle II.
And definitely a regulator. It might not be as brilliant as the stock Streamlight Ultra Stinger, but it won't be a slouch. It should run longer than the stock light, and be constant brightness to boot.
There is a comparison of the Ultra Stinger to the Space Needle II.
SN II faces down incandescent wolf pack
The 5 Watt Space Needle II compares favorably to the Ultra Stinger in these tests, and outperforms it on at least one test that I saw. But the Space Needle II is an overdriven 5 Watter.
The BadBoy 700 drives the 5 Watt at spec., right?
My Megaclops is overdriven, with fresh batteries to about 10 watts. With my cells right now at 1.44V, it draws 850 mA. I assume the Space Needle II is about the same, since it tests better on a light meter, and has a tighter hotspot, due to the high dome.
Perhaps one of the BadBoy 750s, or a pair of BadBoy 500s or 400s paralleled, or a combination of a 400 & 500 (900 mA).
Or for the real go-getter, a BB 750 paralleled with a
BB 400 or 500 (1.15 A - 1.25 A). For the maniac, (2) BB 750s. /ubbthreads/images/graemlins/eek.gif
Do you know what the capacity of the standard battery pack is for the Ultra Stinger?
