abvidledUK
After much deliberation and reading of previous CPF posts, I opted to try out DX Ultrafire Protected 880mah RCR123, along with the DSD charger.
I immediately swapped the supplied US style two pin PSU for a UK 3 pin Nokia charger, having read stories about the supplied PSU not liking UK 240v.
I partially discharged one cell, fully discharged the other, but not too low as to invoke protection, ( wonder what the low setting is for the protection circuit in these ? ) using a couple of the DX A1 Cree single CR123 torches.
Open circuit DMM volts read:
1) 3.71v partial discharge
2) 2.74v full discharge
Under load
1) 3.48v partial discharge
2) 2.46v full discharge
I then placed both cells together into the powered DSD charger, as above
Initial open circuit DMM volts across terminals on both cells was 3.68v
After 90 minutes, volts across was again equal, this time 4.11v, as the green charged LED came on.
(During the latter stages of charging I measured 4.21v)
Once green LED came on, current through the RCR123s was only ≈ 0.001ma, so no trickle charge there, at least not with the protected RCR123s.
As I understand it, the DSD charger gets around not having independent charging channels by initially charging using CC, until both cells are balanced, then finishes off the charge using CV.
During charging I noticed a very, very small rise in cell temperature, perhaps less than one degree, none in the DSD charger at all.
Almost indiscernible. Couldn't really feel any rise when cell held against nose !
Charge current rated at 450ma.
Certainly much less than the usual temperature rise in nimh cells when being charged, in their charger.
I then again discharged both cells in the A1s, high setting, until LEDs became dim, at the same time. (25 mins)
The A1's became very hot for 20 minutes.
Measured o/c volts were
1) 3.08v
2) 3.12v
So it would seem that the DSD charger does indeed quite well charge individual cells with unequal remaining capacities, even without independent channels.
(See photo of innards in this thread)
http://candlepowerforums.com/vb/showthread.php?p=1559323
with excellent before photo.
Such a simple circuit too, perhaps other manufacturers should copy.
Measuring the initial current consumption through the torch at the setting below, gave me an approx capacity for the protected RCR123's DX rated @ 880 mah of
a) High 790ma ≈330mah
b) Med 280ma ≈420mah
3) Low 50ma ≈500mah
So, in conclusion, the Ultrafire "880mah" Protected RCR123s have a capacity of around 500mah, they charge for around 90 mins in the DSD charger, which does have +ve and -ve marking, but etched into black plastic, hence my paper labels.
I did this, after despite checking, I managed to insert a single RCR123 the wrong way round, but the protection circuit did it's job, and when after 4 hours I still go a red LED, and spotted my error.
No measurable damage to RCR123 at all, nor to the DSD charger.
https://www.dealextreme.com/details.dx/sku.936
https://www.dealextreme.com/details.dx/sku.3273
https://www.dealextreme.com/details.dx/sku.16844
PS: Due to the slightly longer cell length due to the protection circuit in the base of the cell, two of these are too long for my P3D's
